Old 10-06-2019, 12:19 PM
vargafarm vargafarm is offline
Default 1863 cranks but no start
My BIL has a clean 1863 that wont start. Ran great, but then no start. Any common problems to check first? I'm more familiar with troubleshooting older coil style cubs.
Thanks
Old 10-06-2019, 01:22 PM
cooperino's Avatar
Thanks
Need more info.. If it ran before, its likely either no spark or no fuel. How long did it sit between last start and now?
Old 10-06-2019, 02:37 PM
Ran a week or so, ago.
Has gas, pump is pumping fine.
No spark, just wondering if any common problem to this series.
Old 10-06-2019, 02:52 PM
cooperino's Avatar
OK so you confirmed no spark. If thats the case then there are a few things to check.
I would start by checking the kill wire. Unplug the kill wire at the shroud and try to start it.
If the kill wire is grounded it will not produce spark
