Old 10-12-2019, 10:45 AM
Bigsauce Bigsauce is offline
Default Lift rod for qa36a snow blower on a 149
Been putting this off for awhile but winters coming so I thought I’d take care of it before the season is upon us. I’ve got a 149 with a qa36a snow blower attached. The issue I’m running into is that my current lift rod only picks up the blower about 2-3 inches off the ground. It appears that my lift rod is too long. Does anyone know what the proper length for the rod is and where I could go about buying one or even making one? Any help is appreciated.
Old 10-13-2019, 08:08 PM
kalebevans kalebevans is offline
In my opinion it's not a great design. Even with a shorter lift rod to get it all the way to the top of its travel you'll have issues, because it won't want to set down low enough for curves where it needs to sit below the wheel level. I have wanted to make or buy an extension for the lift mechanism that sits by your foot to get more travel in both directions. Xtreme Motorworks makes one I've had my eye on for a bit: https://www.xtrememotorworks.com/Par...Cub-Cadet.html
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original!
Old 10-13-2019, 09:13 PM
I can make an adjustable length lift rod for you if you want.
Jeff
Old 10-17-2019, 01:50 PM
Jeff
Thanks, I’ll send you a pm.
