Old 10-29-2019, 11:55 AM
gost530 gost530 is offline
Default Dads 122
In 1966, my Dad bought a new Cub 122. Recently I found his old tractor and purchased it. When Dad bought it, the deck was a 48 inch. Someone converted it to a 38 in quick connect. I have a 42 inch non quick connect and a few quick connect decks in pretty sad shape. I only have the carriage for a quick connect deck. Is it possible to drill the ends of the carriage and weld the pins to accommodate the old non quick connect deck?
Old 10-29-2019, 03:09 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Maybe you can take the quick attach brackets from the 38 and transfer it to the 42 and use the QA carriage (mule drive). I did that with a 42" cast iron end deck and it worked well. I think you'll need to change to the loops link assembly on the front of deck. I also remember need to drill holes in the deck for the QA brackets.
Plow blade
#2 Cart
QA36 snowthower
Old 10-29-2019, 03:26 PM
Thank you that is what I wanted to do. I don't believe the cast iron nose will interchange and not sure that I can use the front oblong hangers on the pin type deck. Sounds like they will work thank you
