Old 10-29-2019, 04:22 PM
xcookpac xcookpac is offline
Default Snow Plow Angle Mechanism
I have attached some pics of a snowplow angle mechanism that I saw on a Simplicty lawn tractor. Most impressive parts of the mechanism are the following:
1.) when the operator pushes forward on the angle rod the angle lock mechanism temporarily unlocks; and
2.) when the angle rod is rotated, the plow angle rotates.
This is all accomplished with manual mechanical method (no electrics nor hydraulics used).
Does anybody have any experience with this type of angle mechanism?
Old 10-29-2019, 05:01 PM
I was have trouble editing. Instead, a 2nd posting on same subject.
I have attached a parts schematic (as one more pic) obtained from Jack's Small Engines. See: https://az417944.vo.msecnd.net/diagr...de/diagram.gif
File Type: jpg 10292019_simplicty_plow_angle5_good.jpg (22.2 KB, 681 views)
Old 10-30-2019, 08:58 AM
I was hoping to fabricate a similar setup for the snow plows on my CC100 and CC122.
Old 10-30-2019, 10:37 AM
The problem is that IH built Push Blades have a "pull up" pin that needs to be lifted to angle the blade.
Old 11-01-2019, 12:11 PM
Good point!! Which means I would be probably better off finding a Simplicity plow blade and mating it to my NF CCs. Clearly this project is going to take time.
Old 12-08-2019, 12:59 PM
IHinIN IHinIN is offline
I’ve started working on an angle mechanism for my blade. So far, I figured out how to convert the vertical pin to a sideways pull setup that will be actuated by a bike brake cable or choke cable.
File Type: jpg 2D18EFA2-81A5-4214-A73A-EB81DFE9490D.jpg (18.2 KB, 547 views)
File Type: jpg E96339C3-EA7F-43D7-B565-CC1BC523E6E0.jpg (16.1 KB, 545 views)
Old 12-14-2019, 07:03 PM
I almost have it done. The lock pin release works well. The pipe needs an offset to connect to the rod end and clear the front tire.
Old 12-14-2019, 08:56 PM
athomas's Avatar
athomas athomas is offline
Looks good !
Old 12-15-2019, 08:40 AM
IHCubCadet147's Avatar
Nice work!
Old 12-15-2019, 01:29 PM
Thanks guys! Finished the release mechanism. The cable will get shortened after I finish the angling pipe.
File Type: jpg 8DBDA80B-5CC9-453B-AE1A-C60393266B7B.jpg (24.0 KB, 363 views)
File Type: jpg 123EE94C-5DBD-4384-9E63-954EFCA42D7B.jpg (23.8 KB, 363 views)
Tags
plow angle, simplicty, snow plow
