For about 2 weeks I been trying to figure out what leaking on my transmission on my tractor after unclean it up and refilled the trans with new fuild and new brake push rod o ring. My tractor is a 124. I thought it was coming from the coupler where the driveshaft connects but that not it after I lift up my seat and take a peek in the gear shifter area. It seem to be leaking out of that plug? What is it?
Looks like where the breather is on a GD.
Supposed to be a sintered brass insert in there. Has someone plugged it with something?? Did you overfill the transmission by any chance?? |
That was my 1st thought but I remembered to stop when it starts to come out the fill hole.
Clean the area real well with brake cleaner and the get some baby powder.
Wait a few minutes after cleaning and then fuff it on the area around the suspected area. From your picture it looks like the gs cover is leaking...
Up to 534 and counting... I give up updating my profile! |
What is gs? Why would it leak when the oil level is way below the gear shifter area.
GS gear shift.
Because it travels up from the bottom thru the action of the gears turning, like those thingies they have at the auto parts store for Lucas oil.... Use the baby powder trick and any left over put on you bumm....
I think Lew has nailed it.
did it leak before?? what did you use for oil? I assume you put in in through the plug in the rear cover? |
Not sure if it leaked before. It was covered in grime, grease before by the previous owner and I pressure washed it. I use hytran oil through the fill hole on the back plate.
Now that I look at it more, that is the back side of the gear reduction housing, that is the GRD shaft. I believe that there is suppose to be a welch plug covering it.
"welch plug" As in Welchit! I lost ma plug! lol. I believe you are correct tho.
