Old 11-25-2019, 04:39 PM
danman danman is offline
Default Ugh ! 60" haban deck new belt install NOT
what is the trick to get this new belt over the pulleys?
cannot compress the deck idler spring enough
purchased a 116" belt. shoukd work fine.
argh!
Old 11-25-2019, 06:54 PM
They are a Royal PITA. I use a pry bar that is about 3' long. One end on the pulley and against the pivot for the tensioner. Pry bar in red, direction to pull the pry bar in yellow.
Old 11-26-2019, 09:08 PM
V30crewcab V30crewcab is offline
Just had this exact problem. thought I had the wrong belt. used a prybar on the tensioner, and had to grab the belt and roll it around the pulley to get it on. crazy tight.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 11-27-2019, 06:09 AM
cubby102's Avatar
cubby102 cubby102 is offline
Welp, that explains why my engine Boggs WAY before the belt even thinks of slipping
Old 11-29-2019, 02:20 AM
Steve N Mi Steve N Mi is offline
It can be done without a prybar but it takes two. I held the idler back while my son in law slipped the belt over the last remaining pulley. Good to see the prybar technique as I don't usually have another pair of hands available.
The Hayban made 3 deep chops into a stump root before the kevlar belt burst and there was a piece 3 - 4 inches long missing from the OAL that I didn't find.
