Old 12-17-2019, 11:02 AM
thadscub's Avatar
thadscub thadscub is offline
Default Need help with hydrostatic transmision on 123
hi guys i have a weird issue on my 1967 cubcadet 123 where the speed control lever is in neutral. but the transmision still creeps have tried to find neutral again. what else could be causing this.
thanks thad
Old 12-17-2019, 11:34 AM
cubs-n-bxrs's Avatar
Couple things could be causing this. Worn out trunnion not letting it find neutral when the pedal is depressed. If this is the case the tractor will have to be split to repair this issue. The cam bracket could be out of adjustment. The 105/125 service manual goes into pretty good detail on how to adjust neutral. I checked the 123 service manual and it doesn't go into that great of detail on adjusting this.
