Old 02-11-2020, 04:46 PM
Dirtpusher Dirtpusher is offline
Default 125 with hydraulic lift
I picked up a 125 with hydraulic lift last summer, pretty cheap but its non running. Now I'm laid off for a month and bored so I'm working on getting it running. I have never had an early hydraulic lift tractor so I'm kinda ignorant about these pumps. Other than having it full of hytran is there anything else I should know before I do much with it? I didn't get it running yet but I hope to tomorrow!
2 0's, 70, 100, 4 122's, 4 124's, 2 125's, 73, 106, 86, 109, 129, 128, 148, 149, 2 1200's, 1250,1450, 1650, 580, 3 haban sickle mowers, and few other brands plus a junkyard full of parts and projects.
Old 02-11-2020, 07:00 PM
athomas's Avatar
athomas athomas is offline
In the tech manual section of the forum you can find the owner/installation manual for the hydraulic lift for narrow frame tractors that may provide info. If you got hytran in it and all else is good it should function. I have one on a 125 that I went through and cleaned up and replaced the seals and lever return spring on and all turned out well !
Old 02-11-2020, 07:08 PM
athomas's Avatar
some pump info
Old 02-11-2020, 09:21 PM
mortten mortten is offline
http://www.cubcadetman.com/cc/how-to...draulic-pumps/
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 02-11-2020, 11:01 PM
Before starting your cub and running your hydraulic lift, besides checking fluid levels, I would also check clearances for the belt, belt alignment, and belt tension. Make sure that if the clutch shield was cut away that it is not loose or touching belt. Check clearances at the back for the actuator. Make sure that it has enough room for full extension. I have seen where someone installed an electric lift guard on one (not for sure why, perhaps for safety) and either it was not mounted correctly or bent and the arm could not fully extend back. That would be rare that yours would be set up that way, but without any pictures of your setup, you never know and stranger things have happened...
Old 02-12-2020, 07:47 AM
Thank you for the information and suggestions guys! As always I've been given good knowledge from good people on here. I feel a little smarter now. Every thing seems to look like it should on the pump and tractor. The belt is aligned and tight, nothing is rubbing or touching, the linkage is still free, and it's not leaking oil yet. The tractor probably hasn't run in 15 years. I pulled the head yesterday and lubricated the cylinder and valves. The motor turns free and the valves appear to be working properly. I cleaned and rebuilt the carburetor last night. It has some wiring problems but I want to hear it run before I go much further. I'll put some fresh oil in it and file the points this morning and see what she does.
