Old 03-28-2020, 11:16 AM
chzuck chzuck is offline
Default Hydraulic lift control lever broke
My son has a 1650 with a possible broken control lever. Anyone on here ever change one that can give us some direction on replacing it? The manual as I recall does not have much info. Looking at the manual it appears removing the gas tank would be the first step. He is not a mechanic and lives 2hrs away and I cannot travel because of the virus and still recovering from hip surgery and a torn tendon. Any help at all would be greatly appreciated. He said the lever had a lot of extra play before it stopped working. I am thinking the hole in the plate on the lever shaft had flats at one time and now they are gone?
Old 03-28-2020, 12:49 PM
athomas's Avatar
athomas athomas is offline
There is a connecting chain link in there that connects the lever to the control valve that may have broken ? I don't recall any flats on anything though,getting the tank off will get you some room I think the link is like a rc 140 available at tractor supply for like 3 bucks or so ? if link works might get u a diagram !
https://www.partstree.com/models/165...aulic-lift-18/
Old 03-28-2020, 02:34 PM
finsruskw finsruskw is online now
There were 2 styles
One is a clamp affair that wraps around the shaft and held tight by a 5/16" bolt.
The other uses a tiny spirol pin to secure a flat to the shaft.
Removing the gas tank will reveal just what style you have.
The bolt may be loose as in the 1st scenario
Or
the pin may have broken in the 2nd
Old 03-28-2020, 06:16 PM
I've also seen the shaft break where the pin goes through.
Old 03-28-2020, 06:24 PM
Hopefully the clamp has not been welded, then it is a matter of a few cuts and bruises to remove it.
Just make sure you do not loose any parts.
Old 03-29-2020, 09:35 AM
I have seen them busted as well.
Problem is, the spool only moves a small distance in the valve body.
People get the wrong idea that it should move more because of the long operating lever. And because of that much leverage folks use way to much force on the lever and that is what causes the issues here.
From broken pins, lever arms and slipping clamps.
Old 03-30-2020, 06:48 PM
Does anyone have a diagram showing the pin style. My son needs all the assistance he can get. He is not too adventurous on mechanical things without a good bit of help and he is 2 hours away and I am in a stay at home area.
Tags
hydraulic, lever
