Old 03-31-2020, 12:53 PM
Rex B Rex B is offline
Default What defines a Super?
I recently bought a 2084 which I understand is a Super Garden Tractor.
I also have an 1864 which I always thought was a SGT. The differences are pretty minor - The 2084 has 2 more HP, a wider rear track, and no CAT-0. The 1864 looks to be the same size, though it's 100 lbs lighter and has the CAT-0.
So what makes the 2084 a Super, and the 1864 not a Super?
Old 03-31-2020, 01:12 PM
Generally Speaking------
(A) 20+ Horse Power (some 15 & 17HP Diesels and a few 18HP gas engines)
(B) Longer frame (front to back, about 7 " longer)
(C) Higher stance. (18 x 8.50 -8 Front tires, 26 x 12.00 -12 Rear tires)
(D) Rear PTO
Old 03-31-2020, 01:36 PM
CubDieselFan's Avatar
It sounds like the 3 point is what is confusing you. The 3 points were an option for both the SGT and regular GTs. Your 1864 just happens to have an option the 2084 does not.
Old 03-31-2020, 01:43 PM
The rear PTO was also an option. My 982 does not have a rear PTO, but is still a SGT.
Old 03-31-2020, 08:06 PM
Longer wheel base indicated by the longer tunnel cover
Old 03-31-2020, 08:26 PM
Today I measured the wheelbase 7” longer.
And the rear tires are 26” vs 23” on the 1864.
I *thought* it looked a bit large when I picked it up ��. I arrived with a 4x8 trailer and was afraid I had misunderestimated.
So, will the cat-0 transfer from the 1864 to the 2084? That might make more sense for my needs. I hate removing that mower deck to use the tractor like a tractor.
Old 04-01-2020, 09:26 AM
The cat 0 will fit but you will need a longer lift bar.
Xtreme sells them or maybe you can find a used one.
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
Old 04-04-2020, 09:26 AM
That would be the lift link bar?
Their complete kits are cheaper than used on ebay. Thanks for the link
