Old 04-16-2020, 08:04 AM
pullin pullin is offline
Default 149 hydro lift port size
Hi, I am not a hydrolic specialist. Could anyone tell me what the fitting description and size is for the hydro lift ports on my 149 pump?
Old 04-16-2020, 08:45 AM
You can use 3/8" tubing (ie: 3/8" steel brake line) and the respective fittings.
Old 04-16-2020, 09:46 AM
People usually cut off the inverted nut brake line fittings,
and put on Parker type *37 flair fittings.( they are standard Hyd fittings)
if you have a Parker store near you they can help.
Also places like Ebay but you need to know what you need there to order.
it would be helpful if we knew what you are trying to do?
if just splicing a line, or adding other things needing to plumb a system
Old 04-16-2020, 07:23 PM
ol'George, I took the hydraulic lift off my 149 because I built a front end loader. Now I need to make a loop at the pump. Thanks.
