Old 04-20-2020, 06:33 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Default Narrow frame pump/ram rebuild.
So, I bought a hydraulic pump for my narrow frame. Finally came in. Is there anything I'm missing? I already got the rocker shaft.
I'm going to order a rebuild kit for the pump itself and I want to make sure i got the right rebuild kit for the pump itself.
For the Ram assembly, who have a rebuild kit for those?
Also, hoses, where can I buy new set?
Old 04-20-2020, 10:12 PM
athomas's Avatar
athomas athomas is offline
looks like the same kit I put in my 125, had new hoses made at a local parts store, didn't have to get into the ram , good luck , mine seems to have turned out ok !
Old 04-20-2020, 10:24 PM
What did you use to refill the system?
Old 04-20-2020, 11:08 PM
athomas's Avatar
hytran fluid ,same as the trans. but I think I read somewhere 10wt oil would work, I think there is some info/manuals in the tech/literature section here
Old 04-20-2020, 11:14 PM
athomas's Avatar
tech library under implements ! narrow frame hyd lift oper manual
