Old 04-22-2020, 08:35 PM
C&O2-10-4 C&O2-10-4 is offline
Default CCC 3240 woes
Has anyone else had major issues with the Kohler Command engines in the 3000, series CCC's ??? Last year it (3240) was bad hydraulic lifters which resulted in bent push rods, I fixed that and all was perfect and then a valve spring keeper broke and let the whole works go, spring and all. New clean oil, everything was getting good lubrication.
I'm actually the third owner and I've heard that the last PO was hard on it, but you wouldn't know that from its appearance.
Thinking about giving up on this one; what would you do ???
C&O2-10-4
