Old 04-28-2020, 07:34 PM
Pwedl Pwedl is offline
Default 782 Rear Lift
I've searched for two days and can't seem to find the answer so here goes , did they make a rear lift for the later serial # 782 Hydro ?? I have a wide frame lift here but it fits the manual lift cubs. Was hoping to make it work but not sure if it will. All the info I can find is for the lower serial # cubs. TIA Paul
Old 04-28-2020, 07:53 PM
How about a picture of your rear end....
Up to 534 and counting...
Old 04-28-2020, 08:07 PM
Uncle Lewy.....Shame on you. That is VERY SUGGESTIVE!
Old 04-28-2020, 08:37 PM
Default Pics
Heres the pic of my rear
File Type: jpg 77AFA029-C012-4BB6-9044-394AD1096827.jpg (30.5 KB, 189 views)
Old 04-28-2020, 11:46 PM
If I recall, the lifts are the same, but the bolts to the frame are different. I have several of each lift (WF) and 82 series, but haven't seen them for years. Just sat them down once I got them and they are in my cub pile. I think the bolts to the 82 series were kind of like Frankenstein bolts. Someone else can chime in with pics or correct me if I am wrong.
Old 04-29-2020, 02:39 PM
Yes the bolts are different. PBJ makes those special bolts. you still will have to see if the lift bar off a quiet line will work though.
Old 04-29-2020, 06:10 PM
Default bolts
Thanks , I ordered the bolts from Jeff today. Pretty sure I need a straight lift arm and the front attaching hardware. But it should work. Does anyone have a pic of how the lift bar attaches up front at the lift cylinder ?? Can't seem to find any pics or info on it. Thanks
Old 04-29-2020, 07:43 PM
It uses a clevis pin that holds it on the rock shaft arm.
Old 04-30-2020, 09:22 AM
jbrewer's Avatar
jbrewer jbrewer is offline
I have a Cat 0 lift for my 782D. Dunno if they're the same for the 782.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-30-2020, 04:10 PM
Rbertalotto Rbertalotto is offline
Can I join the conversation? Here is a photo of the lift mechanism on my IH 782 (Ser # 731511)
Where would the lift arm for a rear sleeve hitch or a three point hitch attach?
