Old 04-30-2020, 02:00 PM
MrRazz MrRazz is offline
Default Hydro linkage slop
Hey all,
I've been working on getting some things done to my 1250 lately and I've moved on to the hydro linkage. It has quite a bit of slop and play in it. I ordered some shims for the trunion bracket and will tackle that on Monday, when they get to me. As i was taking a look at the trunion are i noticed the "bracket" or whatever u call it right before the trunion area has some play in it. It likes to wiggle around. I will probably have to shim that also. Does anyone know what size ID I need to get for the shims? Shimming seems like the only solution i can think of. I will put some pics of the location I'm talking about.
Quietline 1250
Old 04-30-2020, 02:28 PM
Here is a image of the 1250 Hydro Linkage as from the Parts Manual.
Are you referring to item #21 ???
Old 04-30-2020, 07:15 PM
Part #6 where it mounts and rotates
Quietline 1250
Old 04-30-2020, 07:16 PM
Im pointing to it with the blue stick in the picture
Quietline 1250
Old 04-30-2020, 07:56 PM
You will need to replace #IH-548057-R2 Cam Assy, Control.
Old 04-30-2020, 08:37 PM
Well I just tore into it and I do not need to repkace the cam assembly. Nothing is wore on it and all is well with it. But what I did find is the pivot bushing is worn. Its #8 in the diagram. So i will be replacing that asap so i can get my machine going for some stone hauling next week.
Quietline 1250
