the fuel pump on the 1811 started leaking, this is the second time in 4 years
Cub Cadets & IH tractors 1811 - 1090 hours 1872 basket case, rebuilding. #1 tiller 1 Farmall regular |
Sounds good.
Are you buying/doing something wong/wrong.
![]() I've got pumps on those double breasted Kohlers that are 20+years old. Where is it leaking, diaphragm? fuel into the crankcase? externally ? Did it come loose and leaking engine oil? Sometimes the needle valve leaks in the carb.and the fuel pump gets blamed. BTDT inquiring minds want to know. ![]() |
![]() Quote:
first pump was original and started leaking into oil,i was lucky to catch it early. i had a used spare off of a bad engine so i installed it so i could get back to mowing. after a couple hours running this spring it started leaking fuel out the side of the pump body.
![]() I just thought i would go electric to prevent any engine damage if i have one leak internally again.
Advice?
electric will work if you want to go that way. Me, I'd go genuine Kohler mechanical for a few bucks more. They are made of plastic now (no corrosion) and use an "O" ring instead of a gasket on the mounting. You can sometimes find favorable prices on the 'net/ebay Either will work. equally well, your choice. ![]() |
