Old 05-07-2020, 11:06 PM
sbybee sbybee is offline
Default 1914 starter
It has been a while. I am now working on a cub cadet 1914 two cylinder Kohler and believe the starter is going out and don't see how to remove it . I can barely see it with the engine shrouds off. Wondered if there was a trick before dismantling it farther. No books on it yet. Any suggestions would be appreciated. thanx steve
Old 05-08-2020, 05:27 AM
Steve, what engine do you have? The original was an Onan B48g. Do you have a Magnum or Command in it now?
Old 05-08-2020, 10:30 PM
I don't know how to tell which engine it is. It is a 2 cylinder.
Old 05-09-2020, 08:22 AM
The 1912/1914 rolled out of the Factory with a Onan B48G engine. There should be some signage on the motor that states so.
Old 05-09-2020, 01:27 PM
Default 1914
You are correct. After a little cleaning I found the tag. It is B48G. It looks like a bigger to get to. thanx steve
