Old 05-08-2020, 11:09 AM
Default Power Steering 1862
Morning Folks
Trying to address a couple of the multiple leaks I have on the
1862. The power steering is the first. It appears to me it is the steering
cylinder itself that is dripping. The drip is coming from where the rod
goes in and out of the cylinder. Can these be worked on at all or is
it a matter of replacing the whole cylinder. 220.00 dollars for the part
hopes the answer is they can be fixed. But am afraid the answer is replace it.
What do you think?
Ken
Old 05-08-2020, 11:18 AM
CubDieselFan's Avatar
Here is some reading for you.
https://www.onlycubcadets.net/forum/...linder+rebuild
Old 05-08-2020, 12:40 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
sorner was a BIG help when I had to do the cylinders over for my 1772. He had all the sources and part numbers I needed. Cylinders you ask? I was originally just take the cylinder off that was leaking internally and replace it with one I bought that was "supposedly" gone over and working 100% with no leaks internally or externally. That replacement cylinder was even worse than the one I took off. So, I just bought 2 sets of seals and did both of them up at the same time. I measured where the parting line was for the cap on the cylinder, then smoothed out the existing weld and used a pipe cutter to open it up. This worked perfectly and had a nice edge to weld back together. The only problem I had was the plastic wire spool in the miller-matic decided to disintegrate. When the wire stopped feeding, I opened the side panel and what came out was like a tangled slinky.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 05-08-2020, 06:29 PM
Thanks guys for the link , that was indeed a good read and for the
hop[ it actually works Frank.
On to the next leak and its a pretty big leak. It took me till I pulled
the mower deck off to realize where my fluid was going. On top of the deck.
It seems to be leaking right above the white line in the picture.
Is it just the O rings in there or something else I need to be aware of.
Other then the leaking the Power Steering is working great.
Ken
Old 05-08-2020, 08:13 PM
Sam Mac Sam Mac is online now
Looks like time to rebuild the "Pump" as it's called or control valve. Oak has good write ups on what to do.
Old 05-10-2020, 11:11 AM
I was afraid you were gonna say that Sam. Looked through Oaks
pics and such and would not even attempt it without his groundwork.
Great stuff. Still a little above my skill level but will have to give it a shot
one of these days.
Ken
Old 05-10-2020, 02:20 PM
Ken I have the complete PS setup of an 1862 that I parted. Yours for $200.00 plus what ever the shipping will cost.
Old 05-10-2020, 05:02 PM
Sounds like a deal Sam, thank you. Let me know how you want to figure it out.
I can give you a phone # and we can sort out the details or emails or
whatever you prefer
Ken
Old 05-10-2020, 05:22 PM
I sent you a PM
