Old 05-08-2020, 06:31 PM
woodworker woodworker is offline
Default 2082 no spark
I have a 2082 with no spark. Pulled motor, the kill wire is unhooked from the coils. Now, I get spark at coils. When I hook kill wire up to both coils - no spark. But if I hook up the kill wire up to one coil, I get a spark. I see no diode in the white wire between the two coils. Only diode I see in the motor are the ones that go to the fuel solenoid.
Old 05-09-2020, 08:25 AM
The White/Yellow is grounding out somewhere. Follow the kill wire to where it exits the shrouds and look for bare spot(s).
Old 05-09-2020, 11:39 AM
cooperino's Avatar
Since you have the motor out and assuming shroud is off. If you hook up the kill wires and you loose spark it must be something grounding circuit.
Or..One coil is somehow effecting the other while connected. Thats the whole reason for the diodes actually anyway.
Did you get the tractor this way? Or did it run and this just started to happen?
