Old 05-09-2020, 11:08 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Default Voltage Regulator Test?
Is there any way to bench test a voltage regulator?
Old 05-10-2020, 06:32 AM
twoton twoton is offline
I assume you're referring to a voltage regulator for a starter/generator.
On Bench testing;
https://www.onlycubcadets.net/forum/...536#post317536
Good reading;
https://www.onlycubcadets.net/forum/...559#post315559
and;
https://www.onlycubcadets.net/forum/...017#post180017
Starting on page 1 - 31;
http://ccmanuals.info/pdf/1x6-7%20Service%20Manual.pdf
and;
http://www.ruiter.ca/mc/info/PDFs/1R-116.pdf
Good luck!
Old 05-10-2020, 10:29 PM
Yes, it would be for a starter generator. Unless I missed it, I don’t see anything about testing in your links, just adjusting.
Old 05-11-2020, 10:36 AM
Sorry, that's all I got.
Old 05-11-2020, 10:48 PM
No problem, hopefully someone else will know.
Old 05-12-2020, 08:12 AM
cooperino's Avatar
Ive never seen a bench test procedure for one. However, you could put it in a tractor with a know to be good harness and SG and follow the normal test routine if need be.
Old 05-12-2020, 09:26 AM
Red Dave Red Dave is offline
You certainly could put it on the bench and check connections, test continuity, check contact closure etc. A real bench test would require a generator or something to simulate the generator.
A local starter/alternator shop around here can test a generator and it's regulator using a test jig and an electric motor turning the generator, I've seen them do it.
It is probably a home brew rig, but I can't imagine this little shop is the only one with the capability.
Old 05-12-2020, 09:27 PM
Thanks for the replies. It’s not a big deal, I have a VR from a parts tractor that I wanted to test. I guess I’ll find out if it’s any good the next time I need to replace one.
Old 05-13-2020, 07:41 AM
Vrobert's Avatar
Vrobert Vrobert is offline
This guy does a bench test.
In general, the field contact is normally closed and grounded until the gen terminal has over 14.5 volts, at which point it opens.
The bat to gen contact is normally open until about 9 or more volts is present on the gen terminal, at which point that contact closes.
https://www.youtube.com/watch?v=5ngzb_Avfkk&t=49s
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 05-13-2020, 07:57 AM
Good video.........IF..........one has a Variac Power Supply.
