Old 05-11-2020, 05:44 PM
rlriii13 rlriii13 is offline
Default Cyclops Tunnel Cover Swap from Plastic to Metal?
My cyclops has one of the black plastic tunnel covers. Before it was mine, the plastic was cracked right where the dump valve rod and ball rest on it for support (go figure). So, I rigged it up so it wouldn't fall down through, and always thought I might replace the tunnel cover some day. Has anyone ever swapped the plastic out for the metal version? I see screw placement is different, but would it fit between the fender and dash?
Old 05-11-2020, 05:49 PM
I think the dash cover is different between the plastic and metal. Check the parts site for parts numbers.
Old 05-11-2020, 06:32 PM
I say,,, get a SGT metal tunnel cover, and alter it until it fits,,
With a saw, drill, and hammer, I am sure it will work!!
Old 05-11-2020, 06:57 PM
Who needs a hammer when I've got a loose hitch plate. That thing works just like my hammer!
PartsTree shows the same panel for 1440 and 1641 serials 821060-880000. I can find lots of images of those models with metal covers. Is there a model that never shipped with plastic covers for comparison?
Old 05-11-2020, 06:58 PM
Frank1541 Frank1541 is offline
I switched from the metal one to plastic on my 1541. No problems. You may need to drill new mounting holes. Otherwise they interchange fine.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 05-11-2020, 07:43 PM
Thanks for confirming your swap Frank. Was there a reason you went from metal to plastic? I'm considering the opposite.
Old 05-12-2020, 08:41 AM
No real reason, I thought the plastic version looked better.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 05-12-2020, 08:42 AM
cooperino's Avatar
You forgot torch, grinder, welder, etc..
Just kidding
Old 05-12-2020, 10:19 AM
Just kidding
AHHHH,, Yes,, the "fun" toys,,,
Old 05-13-2020, 05:11 PM
jimbob200521's Avatar
I went from plastic to metal on my 1864 and it worked just fine
-Ryan
Tags
frame cover, tunnel cover
