I have a Kohler 321 that the parts diagram shows carburetor 47-853-30.
However, the carb on my engine looks to be replacement, it is marked 47-053-04 but I cant find any information on this number and I need a rebuild kit. And I double checked thats a 0 not an 8 on my carb. Anyone know if they might be the same? |
Is it a walbro? then it will need a different kit. If not it will use the same kit the udder used.
Up to 534 and counting... I give up updating my profile! |
how do I tell if its a walbro?
(I apologize, im sure this is common knowledge around here.) |
It will be cast with the name walbro on it. It also will have marks on from throwing it at a wall cause they are a PINTA to rebuild.
![]() Amen!! |
Where is the casting mark usually? I see that part number cast into it but not walbro.
If you don't see it then you don't have it.
The kits are the same for both carbs you mention. Is this the same engine that is in the 125 with the funny dipstick?
Thanks for the laugh!
Loader 102 with Snow Thrower 147 with wood chipper 782 rebuilt With 50" belly mower 1200 with Haban Sickle Bar 1450 restored with Roto Tiller 1512 with Snow Plow |
Been searching around and I still can't tell how to identify an original Kohler carb from a copy?
A walbro will only have one adjustment screw
A Carter will have 2, an idle screw and a high speed screw. Post a picture of it. What's wrong with it anyway? |
