Old 05-17-2020, 11:41 AM
SCPRICE's Avatar
SCPRICE SCPRICE is offline
Default Carburetor Flooding?????
LTX 1042
I ran my mower a month ago with no problem. The fuel tank was full when I parked it.
Three days ago the engine would not start. I took off the air filter and the carburetor was filled with gas and my fuel tank was empty.
I removed the deck and installed new blades, repacked bearings and a pulley, changed the fuel filter, oil filter, and even replaced the carburetor and I'm still getting a flooding problem.
It now runs but chokes out after about 50 feet with the carburetor filled with fuel.
Can someone give me a hint on what to do next.
Old 05-17-2020, 03:47 PM
CubDieselFan's Avatar
Sounds like the float is stuck open. Time for a fuel system cleaning.
Old 05-17-2020, 05:15 PM
SCPRICE's Avatar
Default Thank you for the reply.
The fuel that was in the tank was fresh fuel. I replaced the fuel filter, oil filter, air filter, carburetor and gaskets. After a third time this morning, I was able to get it started and running. I put a valve in the fuel line to prevent any further fuel spilling on the ground. So far so good. I'm getting a fresh tank in the morning and will attempt to go more than the 200 feet (that's as far as I had fuel today) and cut the grass. I'm still not sure why the fuel was flooding through the carb though.
Old 05-17-2020, 07:32 PM
cooperino's Avatar
Answer was in post #2
Tags
carburetor flooding
