Would the 91 be too high of an octane for my 1977 1450? Or would you run 87 with an additive to negate the ethanol? I thought I was doing my boat a favor by using the 91 until the mechanic informed me otherwise.
![]() 1982 CC 680 HYDRO 1977 IH 1450 1992 WH 314-8 lol
No and no.
Higher octane on low compression motors is not economically advantageous,
and at times decreases power, but it is negligible from the operators seat. Higher octane burns slower. I'm not a fan of today's 10% ethanol, but have used it with mostly no problems. What I do encounter are problems with corrosion in fuel systems like carb bowls/jets emulsion tubes where equipment sets idle for more than a couple of years.
We are lucky here in Iowa as most of the Casey's stores have non ethanol gas at the pumps
I use it all the time and add 1 oz MMO per gallon. No fuel issues here. |
I run 90 non ethanol in my 1250 with no issues
Quietline 1250
Thanks fellars.
In these parts it is not worth the extra $1.25 a gallon for non alky gas
and having it be a year old or more.
The only opinion I have on using E 10, 87, 89 octane gasoline for the last umpteen years is, if you store the stuff in sealed containers, don't let it sit in an unused gas engine for 3-4 years, you'll have no problem with it.
If you choose to do otherwise, you can have problems with moisture. Water in gasoline used to be a problem before E 10. Corrosion, dried gas varnish and all that stuff is nothing new. Don't blame it on E 10. |
![]() Agree with Mike Poor storage habits causes more problems
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
