Old 05-31-2020, 07:57 AM
bctc369's Avatar
bctc369 bctc369 is offline
Default 1970 cub 127
OK have a question the other day i was taking parts off to paint .key switch off battery still hooked up . started to unbolt voltage regulator to paint area behind it has soon has i got bolts loose motor started turning over wires started to get hot i hurried up and unhooked battery .what would cause this .
Brian
1970 cub cadet 127
Old 05-31-2020, 08:28 AM
Without looking at the schematic, a voltage regulator needs a ground path to work properly, possibly when you removed it, that caused the starter/gen to power up using wires that were not of sufficient gauge.
in-other-words, it short circuited.
I'm sure you learned a lesson about disconnecting battery terminals when working on electrical systems.
I could tell an old story about my teenage son putting his car through the barn door by not doing a battery disconnect first about 35 years ago.
Now do remember to clean the new paint from mounting terminals of the regulator,
or it no workie
Old 05-31-2020, 08:37 AM
bctc369's Avatar
thanks for the reply. that`s kinda what i thought also used the wire schematic from here for the 127 https://www.onlycubcadets.net/forum/...ad.php?t=18458 just wanted second opinion just in case. yea i be leave i will unhook battery next time
Brian
1970 cub cadet 127
