I have a 46” enduro xt1 that I have had since 2017. I’ve never had any issues starting it until last week. I was running it and had to stop for a second to move something out of my way. When I tried starting it again, it would not crank. I figured maybe my battery died. I bought a new battery and still nothing. Then I tried replacing the starting solenoid. It still will not start. Does anyone have any suggestions as to what is going on??? Please and thank you!
Does it have Fuel?
Is it getting Fuel? Does it crank now? Does it have Spark? Does it have Compression? You can start there for troubleshooting... |
Did you shut it off with mower pto on?? It wont crank with that switch on
It does not crank at all. Turn the key and nothing.
I get it.. It wont crank with pto switch engaged,,,
did you check that?? It also wont crank if your brake switch is bad.
Try jumping the solenoid ?
Blown fuse!
Warranty period ended!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
