Old 06-18-2020, 03:50 PM
brucer95's Avatar
brucer95 brucer95 is offline
Default Starter pulley on 122
I’m trying to figure out if I can purchase a standard pulley from eBay or amazon to replace the clutch basket pulley. I’m not going to be using it for pto work anymore and I mangled mine removing it. There are several 1” bore by 7” pulleys but I’m worried about the groove profile. If anybody has any insight or a link to help me out that’d be outstanding! TIA
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706
Old 06-18-2020, 04:38 PM
cooperino's Avatar
You will need one with a collar attached to it or weld a collar on that has a key and set screw. I think the belt is 3/8"
Old 06-18-2020, 07:22 PM
If you buy a molded zinc pulley, expect it to last a week,,
most such pulleys are intended for 400 RPM service,, not spinning a generator at 8,000 rpm,,,
Old 06-18-2020, 08:46 PM
cooperino's Avatar
But Cad... If you spend money on a good pulley that will hold up, Won't you be spending as much as you would on a new PTO basket?? LOL
Old 06-18-2020, 09:03 PM
Hundreds of used ones that are still good.
Old 06-19-2020, 07:32 AM
ironman's Avatar
ironman ironman is offline
Yes, and there used to be thousands. I was surprised to see the prices that an eBay search yielded for what a few years ago was a fifteen dollar item.
A not so wise co-worker once said to me,
"What's rare is expensive, what's easy to get isn't so hard to come by".
Ya scratch yer head, and then it makes sense.
Old 06-19-2020, 08:18 AM
jbrewer's Avatar
jbrewer jbrewer is offline
I think we're past the "great part out" days. This stuff is finite and will get more expensive.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-19-2020, 12:42 PM
Surplus center has some,7-1/4" OD, 1" Dia hole, spoke/ cast iron I believe. ( takes a 1/2 or 5/8 belt)
$25 and change, plus shipping
did ya check Granger?
Tractor supply?
Old 06-19-2020, 12:46 PM
Yeah, which makes it harder for me to throw out old CC parts, even if they are worn out.
It seems like you can't buy anything for a NF cub cadet for any less than $100 anymore.
