Old 08-10-2010, 10:05 AM
cubcadet109 cubcadet109 is offline
Default Vibration
Hello, can anyone on here give me some Ideas of why my cub cadet 109 vibarates so much? If so could you tell me how to fix them? Also should I buy the originally use fiber pto wear button, or a bronze one?
Old 08-10-2010, 10:14 AM
It's a single-cylinder engine; it vibrates. I've never had a problem with the OEM fiber buttons, but a lot of people use the bronze ones.
Old 08-10-2010, 10:52 AM
You haven't really given us much to work with here...
It could be anything from misaligned engine, loose engine mounting bolts, broken frame, bad/worn drive shaft, rag joint, drive hub, transmission coupling, engine out of time, carb out of adjustment, basically anything that moves or goes round and round can cause a vibration.
If it were mine and I didn't know where a vibration was coming from, I would first make sure the engine was bolted down tight, if it is, I would then remove the drive shaft to determine if it's coming from the front or the back.
Either button is fine... Finding out why the button is worn out might just be the answer to the vibration problem.
Old 08-10-2010, 11:16 AM
The button fell out and I can't find it. THe engine is tight. The carb is adjusted correctly and it is in time. The frame isn't broken. Thanks for the ideas I'll go check now.
