Old 06-26-2020, 10:39 AM
IHCubCadet147's Avatar
Default 2135 - A couple questions
I’m working on a 2135 for my aunt, and have a few questions.
First, it’s low on hydro fluid. What kind do these use and how much?
Second, it is missing the linkage from the choke cable to the carburetor. Anyone have a picture of this? I assume it is just a simple linkage and I can make one, but I want to be sure. The red in the first picture shows where it should go, the circles in the second and third pictures show the where it connects to the card and the cable
I’m also planning on changing the engine oil and filter, sharpen the blades, and grease everything. Anything else I should do or look at while I have it here?
Old 06-26-2020, 12:09 PM
I just got done fixing up an old 2135, I used Rotela 15-40 in the trans and a Cub filter.
You may find these guys helpfull for engine parts.
https://www.jackssmallengines.com/ja...tion-10-27-202
Pic of the choke rod.
Old 06-27-2020, 10:29 PM
Thanks Sam, that exactly what I needed. Do you remember how much trans fluid it took?
Old 06-28-2020, 06:05 AM
The 2000's take 6 QTs. Buy 2 Gal's then you have enough for the trans and the engine.
Old 06-28-2020, 10:52 PM
Thanks again!
Old 07-05-2020, 11:17 PM
Another question. It needs an idler pulley on the deck. I have one that I bought a while ago for my 1320 and it was wrong. It is about 0.5” bigger than the original one. Besides probably needing a longer belt, could it cause any issues if I use this, or should I just get the correct one?
File Type: jpg EF831E48-BF17-47AC-84C2-EB6A78E67165.jpg (26.2 KB, 45 views)
File Type: jpg C0E804CD-5AD3-4721-B8BA-F708A2340F5A.jpg (16.8 KB, 45 views)
Old 07-06-2020, 07:52 AM
Get the proper one or replace the bearing in your old one. You can drill out the spot welds, replace the bearing then bolt it back together.
Old 07-06-2020, 12:51 PM
Thanks, I think I will replace the bearing.
Old 07-06-2020, 03:34 PM
'And to answer your question, you can prolly use the larger Dia. idler
depending on how the belt wraps around it.
If it just leans against the belt, the tension spring will compensate for the slight increase.
if the belt wraps around 1/2-3/4 of the diameter, it might not work.
I'd for sure try it, no harm no foul.
I'd still rebuild yours if possible as a spare if it can be rebuilt.
I have seen some that the outer bearing race is part of the idler, in that case
a new bearing is not going to work as it wouldn't fit.
Old 07-06-2020, 10:50 PM
George, I got it apart, the bearing is replaceable. I’m going to get one for it tomorrow and put the old one back together.
