Old 07-07-2020, 06:50 PM
smhughey smhughey is offline
Exclamation LT1042 PTO Clutch Discovery
I had been having intermittent problems with my PTO switch when I wanted to engage the blades. Finally, it just stopped engaging the blades all together. I replaced the ignition switch and the PTO switch to no avail. I decided to remove the deck and take a good look at the PTO clutch itself and discovered that the bolt holding the PTO clutch to the shaft had dropped out at some point in my mowing. The only thing holding the clutch in place was the support bar below the PTO clutch assembly. So . . . before you go knocking yourself out replacing switches check to make sure the PTO clutch is properly attached to the shaft.
Hope this saves someone some time!!
