Old 07-15-2020, 12:41 PM
malibumac malibumac is offline
Default What year is this 1650?
I am trying to find out the model year for this 1650. The serial number is 2050670U591865
Are there any differences in the 16 hp engines in these models over the years?
Thanks!
Old 07-15-2020, 12:52 PM
From what I can find it looks to be a 1976.
Old 07-15-2020, 12:58 PM
August, 1976
Old 07-15-2020, 01:53 PM
Thank you, are there any differences in the kohler engines for the 1650 or are they all the same k341? I just got this and everything appears to be in good working order. I've mowed with it once and am planning on doing the general maintenance items like oil and air filter. It sat for several years, but started right up and seems to run smooth.
Old 07-15-2020, 02:22 PM
The 1650 rolled out of the Factory with a Kohler K341AQS‐71231 engine in it.
Old 07-15-2020, 02:30 PM
Thank you for confirming that!
Old 07-15-2020, 02:33 PM
The 341's were hard on motor mounts.
Check them closely as well as the entire drive train looking for loose and/or worn couplers, spirol pins, rag joints, ball bushings and missing /broken fan and loose or missing pan bolts where the engine mounts to the rails which supported by the ISO mounts to the frame.
Good luck!
