Just picked up a 1711 w/ 2 stage blower and No. 1 IHC tiller, deck, and would like to add a filter for longevity. Got a good deal, as it needed a fuel pump and actually caught fire on the prior owner! (very minimal damage).
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Just cut out your tins for clearance. Did it on my 782 and ran it like that for years. Worst part is the mess when you change the filter.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
As stated, the cooling tins are cut easily and a stone in the die grinder shapes the rough edges to look very professional.
![]() Just make sure your engine can be equipped with a filter, if it does not have a block off plate, you will not be able to install a filter. |
