Old 07-31-2020, 06:47 AM
Default 2182 Cub Cadet
Short story. A guy down the road has a decent looking 2182 for sale. I have a lot of experience with B&S and Kohler CC's. I have NO experience with the Kubota gas engine as used in CC.
Considering the age of the tractor, what specifics should I look for on the condition of this machine relating to the Kubota engine and related components.
The tractor is supposed to have 500 hours on it.
Old 07-31-2020, 10:48 AM
I am at 1400 hours on my 2182. I had a walker ztr with the diesel version of the same motor with 3200 hours on it. neither one has/had an issue with the motor. the cap rotor and wires are a bit of a pain to replace. I dont run fuel with alcohol so I cannot tell you if that effects the carb. the rear axles tend to come loose and leak, sponsors above have the brace to fix that. I have had a few electrical issues due to corrosion on the terminals. simple cleaning fixed them all. still have an extra alternator NIB that turned out to be a dirty spade terminal connection. mufflers can be expensive. I bought my last one from a marine supply store for 1/3 the cub cadet price. I use a car battery instead of the lawn and garden battery. as with all cyclops tractors the plastic bodywork is brittle and breaks easily. I have replaced all three panels at this point with panels from other models - hand cut the muffler hole. it may be a Super but it isnt build like the old stuff!
I love mine-but it is a bit thirsty
2182 rear 3pt, rear pto, all steel sims cab with heat and radio. 54 and 60 inch decks 45" snowblower, lots of three point/sleeve
