Old 07-31-2020, 09:38 AM
sorner's Avatar
sorner sorner is offline
Default 122 snow blade
I picked up a snow blade for my 122 recently, it looks like a brand new plow on a restored/painted narrow frame hanger, but it did not come with a lift rod. It mounts up and everything but the lift arm I have is about 2" too short. It is a reinforced lift arm from a QA42 snow thrower. I thought I read elsewhere that the lift rod should be the same between the QA42 snow thrower and the snow blade. I've made sure the block for the deck height is all the way out so that's not in the way. How long should the lift arm be for this?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 07-31-2020, 09:44 AM
Prolly have to make yourself a custom one, lotsa articles here, as you prolly know on ideas,
from chains cables to pipes/tubing and custom rod like factory and threaded adjustable ones.
Thinking jeff even makes some but not sure.
Old 07-31-2020, 09:45 AM
Sponsor CCSpecialties has the IH 473924 R1 [32"] in stock.
Old 07-31-2020, 10:10 AM
sorner's Avatar
Well that makes sense, I measured my rods (I have two actually) and both are 27" long.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-31-2020, 04:06 PM
sorner's Avatar
I got it sorted out. I used a 1/2” x 36” rod and heat bent it at the ends to 32.5”, drilled pin holes and cut off the excess 1” or so from each end. It looks good as new.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-31-2020, 11:51 PM
Blade and lift rod both look awesome! Nice job fabricating it up. Just need some IH white on that lift rod and you are ready for plowing.
Old 08-01-2020, 10:44 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Default lift rod fab
I practiced my mig welding with a lift rod. I used a grinder to notch out a 'V' groove in some 1/2' rod, bent it over to 90degees and welded away. Looks pretty clean after a little grinding. Also bought some really thin stainless, 1/2" shim washers from McMAster and I use them on lift rods and all over the tractor. They fit where thicker washer won't.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 08-01-2020, 10:59 AM
bugeye bugeye is offline
Very nice. You'll be styling when the snow flies Never windy there, ha ha.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
