Old 09-06-2020, 10:01 PM
rwairforce rwairforce is offline
Default New Coil...which one?
Hi all,
I have a 2186 with the Kohler 18hp Command. I've lost the spark on the number 2 cylinder. I changed the plugs and it ran the same, like on one cylinder intermittently.
I figure bad coil. I've pulled the engine, the cover and took a pic of the coil and part#. I wanted to do all the cleaning under the cover, air ways, etc. It is a dirty mess but the cylinder cooling fins are fairly clean.
Would you replace the coils with Koher OEM for about $100 of with after marker for about half the price. I'm leaner hard towards the Kohler.
Thanks,
Randy
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 09-06-2020, 10:11 PM
Current coil pic..
Randy
John Deere 140 H3
Sears: GTV16
Old 09-06-2020, 10:13 PM
garybotkin garybotkin is offline
You need to test with an ohm meter to see if in fact you have a
bad coil before spending money.
Old 09-06-2020, 11:33 PM
Vrobert's Avatar
Vrobert Vrobert is offline
I just bought a chinese coil from these guys and I'm happy with it, quality and price-wise. It was a dual coil for my M18.
https://www.ebay.com/itm/Ignition-Co...AAAOSw5KdbasQY
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 09-09-2020, 05:53 PM
dbuck dbuck is offline
Smile Coil
I would go with the Kohler coils. I would not be surpised that they were not made in China.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 09-09-2020, 09:12 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Best way to buy kohler command coils
Is this kit 24-755-307-S
I've found it for $99 a couple times
JD x475
Old 09-10-2020, 07:44 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Exclamation
Almost always better to go with the genuine parts, but if cost is an issue, by all means, go with the aftermarket offshore parts.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 09-11-2020, 03:01 PM
I went with two of these on Amazon.
GENUINE KOHLER PART 24 584 45-S MODULE, IGNITION (CDI FIXED)
Visit the Kohler Store
4.7 out of 5 stars 192 ratings
Price: $50.41
I installed and the engine runs good now. It was really dirty everywhere.
I did some cleaning too which couldn't have hurt anything.
Thanks,
Randy
Randy
John Deere 140 H3
Sears: GTV16
Old 03-17-2021, 08:32 PM
Rex B Rex B is offline
Well that is interesting. You can buy two coils for less than MSRP and get a flywheel included for free?
I may need coils for my 1864. This looks like the way to go.
Old 03-18-2021, 11:15 AM
guyina4x4's Avatar
Yes it's worked out really well for me a couple times when the magnets were loose and broken on the flywheel.
JD x475
