I just picked up a 1650. I found some information that does not match? The serial number is 205067OU561238. The, what appear to be original decals, say it is a 1650. But it has a 14 HP Kohler engine. Oh, it also has a small oil leak from the hydrostatic drive that I have not yet been able to locate. Any usual suspects? Thanks!
0670 is a kind code for a 1650. Probably an engine change. Check the cork gasket or the hydro valves for leaks.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
