Old 09-26-2020, 10:19 AM
Greenjeans Greenjeans is offline
Default Hot wire
I repaired the pto clutch on a new-to-me 169 and when I started it up, the wire insulation on the wire to the positive terminal on the coil started burning. I shut the engine off immediately. The tractor ran well before the clutch repair and nothing else changed. I suspect that the voltage regulator may have malfunctioned and let too much current go to the coil, but before going any further, any comment or advice would be greatly appreciated. Thanks!
Old 09-26-2020, 03:05 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Possibly a poor connection at the point of burning where the hot wire connects to coil.
Or a short in the coil, but you say you started it up?
I doubt regulator is the problem.
Plow blade
#2 Cart
QA36 snowthower
Old 09-26-2020, 08:56 PM
finsruskw finsruskw is online now
You mean the ignition coil?
Must be, the 169 has a manual PTO.
Must be something shorted across to ground somewhere.
Time to break out the VOM
