Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 09-27-2020, 07:29 PM
451johnny 451johnny is offline
Default Gas solenoid
hi everyone I have a AGS-2160 with a 16hp engine that won't start and I'm pretty sure its the gas solenoid so can anyone help and guide me as to how to remove and replace it..thanks in advance johnny
Old 09-27-2020, 07:34 PM
You didn't ask but...................
I'd verify it really isn't working. If it isn't working, it's problem not getting 12v or it's gummed up.
The fix? Get 12 volts to it or remove the solenoid and clean it up and re-install it.
I've fooled with a lot of them and only had one that was corroded so bad I couldn't clean it reliably.
When you get the top off the carb, remove the solenoid and idle jet and you can blow all the passages out with compressed air.
