I was mowing the other day and my 1864 randomly started running really rough and then died. I could barely get it to start again. Left it for a day and I was able to get it to start, but sounds like its only running on one cylinder. As soon as I try to give it any throttle, it'll just bog down. It'll move, but the engine can barely handle that regardless of throttle level.
If, when running, I pull off one of the spark plug wires, the engine will continue running with zero change. Pull the other one, engine dies immediately. I replaced the plugs. Both appeared to be giving a spark if grounded to frame, though one side did seem to give off a stronger spark. At this point, what's the best way to determine if it's fuel or ignition? Or is that description enough to make that determination? Thanks |
Do you have compression in both cylinders?
Fuel delivery issue?
I encountered a similar issue on a Simplicity Conquest with a Briggs 18hp engine. In some way, the issue was being caused by a bad air filter. It ran fine without the filter, and runs fine with the new one. However the carb also has some gunk in it still, the throttle wanders until I put it under load (engage the deck). Are you certain it didn't throw one rod? Was there a "clunk" sound when it started running rough? Easiest way to check is by turning the engine over by hand and looking into the cylinder through spark plug hole. I would say fuel issues more than anything, but I can't be certain. Your engine might have a completely different issue than mine had.
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
I don't have a compression tester
![]() Quote:
How loud of a clunk would it have been? But I don't think so, at least nothing that I could hear over the sound of the engine/mower (and wearing ear protection). It was sudden though, not a gradual decline. I'll try turning it by hand and see if there's anything obvious. I'm leaning toward fuel as well, but I'm not familiar enough with symptoms of lost compression or other internal damage to rule any of those out. |
![]() Quote:
Pull both plugs. Stick your finger in each hole and crank the engine. You know one cylinder has enough compression to run. How does the other one compare. Move your spark plug wires away from your hand so you don't get a false reading. ![]() If the problem was lack of fuel, pulling the choke out a little while it's running should smooth it out. |
Yep, gotta agree there. Did that with my Simplicity mentioned above and the throttle stopped wandering. Try letting it run on partial choke, like Mike said. maybe it'll smooth out.
I had the same problemwith my 1864. When mowing in high grass, the engine would bog down. Check the firing, was not firing on the left bank as setting in the seat. The comp was 150 both cyl's. Pulled the engine and replaced both mags. firing fine now, running better than it did before.
Don B, USAF 1962-1968, Ft. Wayne, IN |
Not trying to be a smart ass. But what does a fuel delivery issue have to do with not firing on one cyl?
