Old 10-01-2020, 06:26 PM
jwhill jwhill is offline
Default 1650 heat shield
Interested in tips on what material to use to make a heat shield for the gas tank? Or, is it possible to buy the correct part? Thanks!!
Old 10-01-2020, 07:15 PM
mortten mortten is offline
NLA from Cub Cadet.
There’s this:
https://www.ebay.com/itm/Cub-Cadet-1...-/401891252219
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 10-01-2020, 07:54 PM
That ones screwed up, the standoffs are broken off and MIA
Old 10-01-2020, 08:28 PM
ironman's Avatar
ironman ironman is offline
FWIW
http://www.mowergraveyard.com/sheetm...0-p-16922.html
Old 10-02-2020, 09:48 AM
Thanks much!!!
Old 10-02-2020, 05:55 PM
Still, can't se the side with the tank mounts.
Ask first.
Old 10-07-2020, 04:08 PM
Thanks again for the tip. I ordered this, it arrived Monday and I installed it Monday. Next on to missing hydro cooling fan and small leak.
