Old 10-05-2020, 01:10 PM
TN_Explorer TN_Explorer is offline
Default 782 brake pedal return spring
My 782 brake pedal does not return - I have to pull it up with my foot. The return spring is missing & I can't tell where it attaches. It looks like there is a hole for the spring on the plate with the safety switch (circled in yellow on the attachment). There is a nipple on the pedal shaft (red arrow), but this doesn't look like what I would expect to attach to.
Anyone know if these are the correct spring attachment points?
Thank you!
Old 10-05-2020, 01:39 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Found this thread about the same issue...
https://www.onlycubcadets.net/forum/...ead.php?t=3613
Maybe it can help
I don't own or have experience with a 782 tractor so I wouldn't know
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 10-05-2020, 03:30 PM
Thank you SO much! I don't know why I couldn't find it. Whenever I search for anything for a 782, the search drops the 782 and I get less than useful results. Again, thanks for the response.
