Old 10-08-2020, 01:29 PM
dbuck dbuck is offline
Smile 1864
While mowing sometime the speed will greatly reduce. Specially in a tight turn, or starting up hill. I will have to adjust the hydro lever to go back to the previous speed. Any one have any ideas what the problem may be.
Tthank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 10-08-2020, 01:41 PM
Sounds like when you have a Hydrostatic Load, the issue arises. Check the fluid level first.
Old 10-09-2020, 08:29 AM
Does this mean the speed control lever is moving and you are returning it to prior position?
When you turn the steering wheel, you take some of the hydro volume away from the pump. This can cause a momentary lag but wouldn't require you to move the speed control lever.
If the fluid level is okay, look to see if you can tell if the hydro filter has been changed in the last many years.
Old 10-09-2020, 06:47 PM
Level shows full. Changed the filter and fluid when I had the engine out and the deck off.
Old 10-09-2020, 10:10 PM
CubDieselFan's Avatar
What filter did you use?
Old 10-09-2020, 10:49 PM
How is the hydro lever? I have seen them become loose where it connects to the cross arm. It may have to be fixed.
Old 10-10-2020, 07:25 PM
Speed control lever does not move. Hydro folter just changed.
Old 10-10-2020, 07:45 PM
Post #5. What filter did you use?
Old 10-10-2020, 08:33 PM
He used a Hydro folter
Old 10-14-2020, 01:02 PM
Talking 1864
I used on of them hydro folters, 1014 from Napa.
