I have a 2003 gt2186 with230 hours like new condition. I have had it since new. I have the Factory installed pto belt. The problem it sometimes jumps off the bottom pulley when I first engage the pto. All bearings and pulleys are good. I have replaced the two bottom pulleys two years ago. I can install a old belt and it will stay on the pulley fine. The factory MTD is the second one that I have purchased. It seems like the belt is not exactly the same as old cub cadet belts were. If I idle the engine then sometimes it won’t jump off. I am sure that you have seen this problem before. Thanks for any help that you can give me.
ttt ttt ttt ttt
Sounds to me like there simply isn't enough tension on the drive belt. Had his issue on my old 106, all I had to do was put more tension on it by adjusting the idlers. Not sure if the 2186 has an adjustable idler or not though.
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
