Old 10-23-2020, 05:42 PM
SGragg SGragg is offline
Inactive Member
Default Front Tires
Need your experience with front tires. Never had any of the smooth, ribbed front tires like you see on some of the old CCs (below left). I've always had Carlisle Turf Saver or Turf Master (below right) treaded tires.
Do you all that have the ribbed tires find that they cause the tractor to wander off course or do they track pretty straight?
Thanks.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 10-23-2020, 06:21 PM
mortten mortten is offline
I put a set of Vredestein V61 tires on my 1250. Very easy to steer. They don’t rip up the grass. I find turf tires to be hard steering.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 10-23-2020, 11:53 PM
Stanton,
The ones on the left I have often heard referred to as the "flotation" tires. I've had those on several cubs and I think they are good for only two things.....squashing down the clover before I get a chance to mow over it--giving me a bad cut to the lawn and removing from the cub to replace with something better.
I've had great luck with the skinnies tri-ribs on the front. As mentioned, they make steering easier, as if you have power steering and they track very nicely to guide the cub through snow and turf. I've never used them for dirt plowing, so I cannot speak to their effectiveness there. When I put them on one of my 129's years ago, I was laughing on my victory lap with them because it seemed as though the front of my cub was resting on a cinder block and I was moving the steering wheel freely. The skinny tri-ribs sell new for between $40-$65 with tubes in them.
Old 10-24-2020, 02:12 PM
Stanton,
I agree with all this.
Stanton,
I agree with all this. I second the harder steering part for the "flotation" tires.
Old 10-24-2020, 07:29 PM
Inactive Member
Would you all consider the V61 tires in the “floatation” category or do they provide good tracking as well as steering?
Stanton
Old 10-24-2020, 09:14 PM
I would recommend you try these. They will work on wide rims with tubes.
https://www.bestusedtires.com/deesto...id=EAIaIQobChM
Old 10-24-2020, 09:43 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
All of mine have the smooth rib tires except my O, which has the narrow style ones. 106 and 107 both using original ones, not new, never had any problems. Don't seem to tear up grass, and aren't hard at all to steer with (definitely easy enough to steer 1-handed without trouble). I like the look of those tires, though not sure how they'd look on an 82 series. Just my
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 10-24-2020, 10:42 PM
Billy-O's Avatar
Billy-O Billy-O is offline
The floatation tires, in my opinion, are terrible in the snow and muddy ground. It gives my tractor a bad case of understeer. I prefer wide turfs for summer grass cutting and skinnies for the winter snow plowing and throwing.
Plow blade
#2 Cart
QA36 snowthower
Old 10-25-2020, 10:52 AM
Inactive Member
Thanks for everyone's input.
Stanton
