Old 11-03-2020, 05:05 PM
eberner's Avatar
eberner eberner is offline
Default Parts are not just parts
Sorry if I have posted this in the wrong area.
I'm currently restoring my 1970 Cub 127 repairing or replacing parts as I find them worn or broken. I was at the point of rebuilding the steering box (with several threads on this site). I realized the cam follower was worn beyond repair. I had remembered seeing many recommendations for "Parts by Jeff" I went to the "Cub Cadet Parts Sources" section and found his listing. I emailed him and asked/order the cam follower, while I was at it I added a drive shaft and Drive hub as mine had a L shape worn in it. He suggested I also look at the rear coupler. Sure enough the center hole was egg shaped. When the parts arrived they so much better than my wildest dreams. The machine work is stellar and the welds brought tears to my eyes.
They're are far better than anything from the factory.
And pictures!
https://hosting.photobucket.com/imag...080&fit=bounds
Old 11-03-2020, 08:21 PM
mortten mortten is offline
He makes good stuff
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
