Old 11-29-2020, 03:11 PM
eberner's Avatar
eberner eberner is offline
Default Trying to remove the PTO from a K241
I removed the 6 set screws, but I cant seem to get the thing to budge.
Any suggestions/recomemdations?
Old 11-29-2020, 03:44 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Screwdriver or metal rod, and a hammer tapping on it one side and then the other, repeating the process until it finally comes loose. Took a while but worked alright for me.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 11-29-2020, 07:39 PM
mortten mortten is offline
I use a length of hardwood.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 11-29-2020, 08:36 PM
I would think that would hurt...
Old 11-30-2020, 09:29 AM
Old 11-30-2020, 10:42 AM
Sometimes you gotta be a man
Doug
QA-36A
42" blade
Old 11-30-2020, 06:21 PM
ironman's Avatar
ironman ironman is offline
Some folks say "the harder, the better" but personally, I haven't tried it.
Old 12-02-2020, 09:20 AM
Steve102 Steve102 is offline
Where are you tapping/beating on it? On the pulley or as far back as you can get the implement of destruction?
This is very timely, as I'm trying to remove the PTO on my 102 to rebuild it and it seems welded in place ....
-Steve-
Steve
1966 Cub Cadet 102
Old 12-02-2020, 09:22 AM
-Steve-
I was tapping on the frontmost sheave of the pulley, but being careful to make sure I don't do damage to the surface. Have you by any chance forgotten to remove the three set screws?
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-02-2020, 09:42 AM
Read post #1, First sentence, he stated he removed all SIX of them.
Sometimes one has to give the penetrating oil a chance to work.
