Hello,
I just bought a Cub 1200 yesterday. It was supposed to be in perfect shape, but it’s not. It needs a new starter Solenoid and the carb needs cleaned or rebuilt. I drove it to my garage in 2nd I didn’t notice any real issues. Later I went to put it in the shed and it would hardly move in 3rd finally it took off. The guy I bought it from said it had a new clutch. I’ve tried to get a hold of him to come and get it and give me a refund. He will not respond back! I tried to adjust it, but the adjustment nut is backed out all the way. I sent a video and pictures to Cub specialties. He informed me I need a new driveshaft and throw out bearing. I’m probably going to also replace the disk, pressure plates and teaser spring. I assume I will have to take the Engine out? Any other advice would be greatly appreciated! That spring looks intimidating! Thanks Mark |
That looks like a new clutch to me, When you say adjusting nut do you mean the one one with the spring that connects to the pedal?
The clutch will not work properly if the engine mounts are bad. Have they been replaced? You can go to the tech section and download the service manual and this will help you out.
Up to 534 and counting... I give up updating my profile! |
I have no clue if the have been replaced. It also throws sparks. I’m just going to replace everything including the engine mounts. |
It does look like a new clutch. The pin holes in the plate are still circles and aren't worn to an oval shape. I agree with checking the engine mounts because if they are bad, the alignment of the whole drive line gets messed up.
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
I wish I could post a video here. It wobbles pretty bad also.
I believe you need to make that video public, I couldn't view it.
Thanks I updated it.
