Old 12-19-2020, 01:36 PM
idruthrbfishin idruthrbfishin is offline
Default 450 blower on an 1811
Guys, I need help. I'm no Einstein, but I'm not an idiot either. I've had 3 Cubs, and had blowers on the first two....one was an 1863, the other was a 2150. I never had the blower on my 1811 until now even though I've owned it for 8 years. I normally use a utility tractor with a FEL for snow removal. Well, the utility tractor wouldn't start the other day, and with 18" of fresh white stuff on the ground, I thought I'd try the blower. Something is not right with this setup.....see pics. Auger is running the wrong direction, its pushing the snow away rather than pulling it in.
Old 12-19-2020, 02:44 PM
Do you have a manual to install it?
Old 12-19-2020, 03:45 PM
no, I didn't get one when I bought it.
Old 12-19-2020, 04:01 PM
I just found and downloaded one online. Is the tensioner pulley on the right or left side when seated on the machine? Diagram makes it look like it is on the left, but mine is on the right. I'm starting to wonder if someone put this thing together wrong when it was originally purchased.
Old 12-19-2020, 05:48 PM
It is on the right. Look more closely at the manual. You may have one that has the wrong gearbox on it.
File Type: jpg Screenshot_2020-12-19 772-3926a pdf.jpg (29.5 KB, 88 views)
Old 12-20-2020, 01:30 PM
B440? B440? is offline
One other thing to check (that I have seen before) is, when someone reassembles the 1st stage auger, they mix up the left and right augers, or put them on backwards. This makes the 2nd stage impeller run correctly, and the augers push snow away from the impeller while in operation.
Old 12-20-2020, 03:53 PM
good to know, thanks B440. darkminion_17, My 2nd stage fan does spin the opposite direction from the large pulley, so it's the right gearbox. One other thing, I spoke with the previous owner earlier today, lucky dog is at his winter house in FL. He only used the blower 1 time, on a 3-4" snow snow. I have a vidja of it running from this morning, hopefully I can figure out how to post it here.
Old 12-20-2020, 06:40 PM
Here's the videos, hope this works.
https://youtu.be/wjnspT8nUqc
https://youtu.be/j6HQmLrtB2Y
Old 12-20-2020, 07:14 PM
Yup, remove the augers and swap them. Looks like it's spinning correctly but the augers are moving the snow away from the impeller.
Old 12-20-2020, 09:06 PM
Thanks for your help B440? I'll be removing the augers and swapping them. I think while I'm in there I'm gonna pull the gearbox apart and clean it up, that way I can see what kind of shape the internals are in. New gasket, fresh oil.
