I solved most of the 107's problems today
Did some wrenching on the ol' K241 today in the 107, fixed a bunch of stuff. I know it's Christmas Eve but why the heck not?
So I pulled the valve cover off. Valve clearances were a bit too tight. Exhaust was like .009, and intake was probably .003 or something else absurd. Got those adjusted back to the proper measurements, .018 on the exhaust and .009 on the intake. When putting it all back together I noticed that my reed valve was not functioning properly. I'm not sure if it's supposed to be, but the valve is sprung slightly in one direction. It was on there backwards, and it did not seal the 2 holes in the plate properly. You could see that it was at some time installed correctly as there were wear marks on both sides of the valve. I installed it properly and now it seals properly. Also replaced the fiber filter thingy because it was pretty small. Overall I'd say it was a pretty good day
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
Sounds like a dandy day, all days spent wrenching on Cubs are good days.
Even days just sitting and staring at em just pondering are good days. Ken |
That rig would rid a lot better with 2 link chains!
Actually all the snow melted
So today I decided to bite the bullet and adjust the hydro linkage. Drove her into the barn (running much better after adjusting the valves a couple days ago) and pulled the fenders. What I found I did not expect. The "damper spring plate" (as the manual calls it, makes up the outer part of the trunnion and holds the springs vertically) had about a half inch of play on it and combined with the normal wearing in the trunnion, the mechanism barely even worked at all.
IMG_20201226_125630.jpg IMG_20201226_125710.jpg Fortunately I had the same piece from the old shredded hydro. Simple enough, swap the worn one with the good one. However this did require splitting the tractor. No big deal, easily done, but not so easily in the freezing cold. So pulled the hydro, removed the speed control cam, then the damper spring plate, swapped in the one from the old hydro, put it back together, perfect. Almost no play at all. IMG_20201226_125741.jpg Then to tackle the trunnion wear, I used a temporary fix that I saw on here a while back. Took a thin piece of steel, cut it to fit in the slot, and bent it around with pliers. Worked perfect. Once all together, went to adjust the hydro creep, only to discover that there was no creep at all. Everything had been caused by the slop in the damper plate. That was a nice surprise. Put it all back together, took it out for a spin. Hydro control is much nicer and much more responsive. IMG_20201226_163429.jpg IMG_20201226_163444.jpg IMG_20201226_125723.jpg This leaves a couple things I still need to do: Figure out how to loosen tension on the control lever so that it moves a bit easier, and most importantly, figure out how to get the lever to sit on the shaft without so much play. The latter being top priority because the shear amount of play in the lever prevents the tractor from reaching full speed. Basically another great day wrenchin' on a Cub
Nice work, looks like fun!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
wrenching on the cubs are the best! Looks good..
129, 124 |
It is behind the battery. It may just need some lube...
I bought a crows foot wrench to fit it to adjust mine.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
