Old 12-29-2020, 07:50 PM
oldironfan oldironfan is offline
Default 73 Engine question
Picked up a bunch a parts that used to be a 73. The good news the correct dash tower, the metal dash and I have most the parts needed to complete it. The cub came with with an 8hp Kohler, I have read in "50 years of CubCadets" they used the 8hp as a replacement, has anyone else heard of this?
It does smoke some but I will tear it down and rebuild it if need be, gonna keep the muffler for sure.
It does not have a tank, does the tank mount like it does on the other narrow frames? The blower housing only has one mounting stud on it, I have some pics to show what I have.
Old 12-29-2020, 07:57 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
I don't know much about the k181, but I do know that that muffler is for a Wide Frame model 86 and is pretty hard to find!
Fuel tank should mount the same, it might be the smaller round tank though and not the bigger one.
And yes they did use the k181 as a replacement.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 12-29-2020, 08:05 PM
Thanks for the quick reply!!!
The 73 along with others Cubs came from a gentleman who's father was Cub dealer years ago, that is probably how it ended up with the 73.
BTW: It was pretty cool to watch all the crud blow out of the muffler....
Old 12-29-2020, 10:13 PM
The motor is from a 86, so you need the correct engine or the pto will not align with the mule drive.
Up to 534 and counting...
Old 12-29-2020, 10:50 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
That is correct I had a 70 that had the k 181 in it out of an 86, and I never could get the PTO to line up. If I remember right I think it stuck out to far.
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
